Reaction wheel failures caused by CMEs
  • Reaction wheel failures caused by CMEs
    Quick summery:
    The science paper
    Interesting that the solar event would cause a mechanical failure.
    Oh, goodie, another techie neologism: Relentless Root Cause Analysis. We've come so far from Zero Defects...;-)
      Quick summery:
      The science paper
      Hi Russell,
      I subscribe to and enjoy Scott Manley’s channel. I’d previously seen this edition.
      It is curious the mechanism by which a CME might cause, not just electronic mischief but, a mechanical issue.
      Ralph mentioned:
      Had to google it:
      ne·ol·o·gism
      noun: neologism; plural noun: neologisms
      a newly coined word or expression.
      Ok . . . ?
        Indeed. While I think the mechanical issue is now understood, the curiosity is what is creating the electrical voltage inside a sealed/shielded box. It's so temptingly close when you have spinning disk since a moving magnetic field will create electricity. But the details seem just out of reach.
          My SWAG: There is always residual magnetism, however weak, in magnetic metals. The sun and earth have magetic fields as well. The RPMs of the bearing balls can get very high, which could make weak magnetism in the balls a decent generator. Then, there's static electricity where contact is flaky, such as via a film of nonconductive lubricant.
          Life may not be the party we hoped for, but while we're here, we should dance.
            My thought as well. But then why the connection to CMEs?
            I'm thinking that charged particles zipping by creates magnetic fields.
              They'll be worried about more than anti-friction bearings when the next Carrington Event comes our way...
              Some say about a 1 in 10 chance in this sunspot cycle...
              Reams
                >>But then why the connection to CMEs?<<
                CMEs result from magnetic field adjustments on the sun, and include on ejection, magnetic fields with the ejected protons.
                It is an energetic particle storm, with magnetic effects, which hits anything in their path.
                Reams
