Originally posted by Paul Millner
Symbolic Links
I'm doing that in Win10. It sounds like you don't have a default program selected to open .txt files. When you go though the dialog, is there a check box that says something like "Always use this app to open .txt files."?
Originally posted by Paul Millner View Postbut in 10, that shortcut simply opens a dialog box with half a dozen apps that can open text files. Worse... the dialog box requires me to use the mouse to scroll and select notepad, no quick key way to pick notepad.
Originally posted by Paul Millner View PostHi Bill,
not sure why the Win7 way went away, but how do I do this in Win10?
TIA! Paul
Back then I was often heard to say, "A change is not necessarily an improvement!"
Hi Bill,
That was interesting. What I’d like to do is create a shortcut or link that will open file t.txt, buried deep in the directory structure, with notepad. I could do that in Windows 7, but in 10, that shortcut simply opens a dialog box with half a dozen apps that can open text files. Worse... the dialog box requires me to use the mouse to scroll and select notepad, no quick key way to pick notepad.
TIA! Paul
Symbolic Links
A good article on Symbolic Links. A really good tool where disk space can be an issue. I use them a lot on my flight sim.Tags: None
