Seems the B737 MAX isn't the only airplane afflicted by problems with stall prevention systems.
"While the airplane was under manual pilot control, the airplane activated several downward pitch commands coincident with stall warning, stick shaker, and several associated alerts. The pilot reported “AOA FAIL” and “STICK PUSHER FAIL CAS” messages preceding the pitch command. The pilot was able to stop the automatic pitch commands by pressing and holding the autopilot disconnect button in accordance with the emergency procedure in the airplane flight manual and safely landed at his destination."
A little further in the report:
"Cirrus and Aerosonic (manufacturer of the technical standard order AOA sensor) have identified the probable root cause as an AOA sensor malfunction due to a quality escape in the assembly of the AOA sensor at Aerosonic."
Here's the link to the AD: https://tinyurl.com/yxadc8gm (rgl.faa.gov)
Has there been a sudden increase in the number of unrecoverable stalls happening in airplanes thereby creating a demand for these stall prevention systems? Or have these systems existed in airplanes longer than I'm thinking (more than the past ten years, for example)?
