I am finalizing my panel layout and would like some input.
The setup will have the electric (master, alternators, avionics master) and fuel to the left side.
Just right of the yoke will be the pitot heat and prop heat.
The lighting switches will be to the right between the G3X and radio stack, above the AP controller.
So I have 7 lighting switches that will be in two rows. They are Landing, Taxi, Recognition, Beacon, Nav, Strobes, and the Flasher control.
The Flasher pulses the Landing and Recog lights. But when you turn on the respective switch that light comes on steady, not pulsed.
I plan on the Flasher and Beacon to be on most all the time.
I am thinking to have them make two rows of 4 holes, and just put a cover on the unused hole, in case I need to add a switch.
But either way, which switches on each row and what order. And explain your thoughts.
Thanks.
Thanks.
