FAA EMERGENCY ORDER OF PROHIBITION for the B-737 -8 -9 (aka MAX)
  • FAA EMERGENCY ORDER OF PROHIBITION for the B-737 -8 -9 (aka MAX)
    The FAA has just issued an EMERGENCY ORDER OF PROHIBITION for the Boeing Company Model 737-8 and Boeing Company Model 737-9 airplanes.
    This Emergency Order of Prohibition is issued by the Federal Aviation Administration (FAA) pursuant to 49 U.S.C. § 40113(a) and§ 46105(c). Effective immediately, this Order prohibits the operation of Boeing Company Model 737-8 and Boeing Company Model 737-9 airplanes by U.S. certificated operators. This Order also prohibits the operation of Boeing Company Model 737-8 and Boeing Company Model 737-9 series airplanes in the territory of the United States. Airplanes covered by this Order, if in flight at the time this Order is issued, may proceed to and complete their soonest planned landing, but may not again takeoff.
    SCOPE AND EFFECT
    This Order applies to all persons operating the Boeing Company Model 73 7-8 and Boeing Company Model 737-9 airplanes in the territory of the United States, and to U.S. certificated operators conducting flights with Boeing Company Model 737-8 and Boeing Company Model 737-9 airplanes. These airplanes are hereinafter referred to as the Boeing 737 MAX series airplanes. This Order is effective immediately. This Order prohibits the operation of Boeing 737 MAX series airplanes by U.S. certificated operators. This Order also prohibits the operation of Boeing 737 MAX series airplanes in the territory of the United States. Boeing 737 MAX series airplanes covered by this Order, if in flight at the time this Order is issued, may proceed to and complete their soonest planned landing, but may not again takeoff. Special flight permits may be issued in accordance with 14 C.F.R. § 21.197 and§ 21.199, including to allow non-passenger carrying flights, as needed, for purposes of flight to a base for storage, production flight testing, repairs, alterations, or maintenance. Experimental airworthiness certificates may be issued in accordance with 14 C.F .R § 21.191 to support certification of design changes. This Order remains in effect until the issuance of an applicable FAA order rescinding or modifying this Order. The Administrator will rescind or modify this Order, as appropriate, if the Administrator determines that the prohibitions prescribed herein are no longer necessary to address an emergency related to safety in air commerce.
    Related:
      Some folks say the AR system is subject to management abuse, and recommend a return to the old DER system where DER's would report to the FAA, rather than to Boeing managers, as is the case under the AR system.
      Reams
        What about the 737-8/9 that aren't MAXes?
          All 737-8 and 737-9 aircraft are MAX. The NGs all had the "00" at the end.
