RNAV Arrival
  • Bill Bridges
    I'm not sure what you're getting at about a difference between FAA/DoD plates and Jepp in depicting HILPTs or PTs....today,
    One of the differences to me is DoD uses a "barb" to indicate a procedure turn while Jepp uses a heavy arrow similar to a "procedure track" for a procedure turn. Some of the places I flew into in the military the course reversal on an approach was actually a procedural track.
    I only started using Jepp charts a couple of years ago when by chart service switched to them and I like them. I'd only been using DoD/FAA charts for 48 years. I know I'm old. ROFL
    I really do enjoy these conversations about instrument flying. They remind me of the best job I ever had, an Instrument IP. The flying didn't get any better for me than flying "H" models 20 hours a week with an instrument student.
    Thanks for taking time out of your busy schedule to visit with me about this issue.
  • Jeff Hartmann
    If you (as I) thought this was only a speed trap technology...
    How would you like to wave your magic wand & find out how far everything is away from you? No magic wands needed with Light Detection and Ranging (LiDAR).
  • Scott Dyer DXR/CT
    Originally posted by Tom Charlton View Post
    Hi Scott,
Name:	Sky Writing My Way-.JPG
    Here’s my kind’a skywrite’n!
    Back on 4/26/2018 south of Miami with one of the airplanes I use to fly.
    Cessna TU206 @4,000' with a LiDAR sensor. 20:07 EDT~23:21 EDT
    One way to drive ATC nuts. <grin>
    I will not fly in elongated circles; I will not fly in elongated circles; I will not fly in elongated circles.....
  • Scott Dyer DXR/CT
    Procedural Track a/k/a Procedure Track. When I see a heavy, dark line with an arrow head that would indicate to me that I must fly that course. In the HILT example above I would not have performed a tear drop entry but would have flown the outbound course of 144.
    When I see what I would consider a Procedure Turn symbol I almost always use a tear drop because it works best with my simple mind. When I see a Jepp (and I may be misreading the IAP) the Procedure Turn looks like a Procedure Track to me and I must fly the course as published.
    Bill - You could do a direct entry, and turn to 144 outbound when direct ORTMN from WAGNR, that's ok too. And in civil flying, you can do just about any old course reversal (on the designated side of the course) that you want to do when a regular procedure turn is depicted.
    I'm not sure what you're getting at about a difference between FAA/DoD plates and Jepp in depicting HILPTs or PTs....today, anyway, they are pretty much the same and all derived from the underlying regulatory approach description. The only thing about HILPTs in civil flying is that you must "enter the hold" when the HILPt is required...but entering the hold merely means that you cross the holding fix on the entry, you needn't do a circuit. Thus, for the HILPT that is illustrated, if you decided to do a teardrop entry on reaching ORTMN from WAGNR, you would turn to a heading of (about, no wind) 100, fly that for a minute (maybe less depending if there is a tailwind), and then turn right to intercept the inbound final approach course outside of ORTMN. HILPT complete, without having to fly a 144 degree course at all.
  • Scott Dyer DXR/CT
    Much the same!
  • Jeff Hartmann
    and there is no NOPT
    OK...reread, you threw in a hypothetical, not this actual situation. (Roseanne Rosannadanna, Never mind))
  • Tom Charlton
    I was out doing a little skywriting this afternoon.
    Hi Scott,
  • Jeff Hartmann
    Scott..
    Bill -- If you are flying the segment from WAGNR to ORTMN, and there is no NOPT on the chart, then you must fly the HILPT.
    Am I reading this wrong. As I see it, if you are cleared to WAGNR, cleared for the approach, there is only a smart turn to final approaching ORTMN. Unless you meant if approaching from anywhere outside of the NOPT semicircle, but then you would not be on the segment, you would go direct ORTMN and HILPT.
  • John O'Shaughnessy [FCM]
    Originally posted by Ralph Jones View Post
    Looks like a cave painting of a bull...;-)
    Wow. Now that you mention it...
  • Ralph Jones
    I was scribbling too
  • Andy Alson
    Thanks, Andy, I was out doing a little skywriting this afternoon.
    I noticed. Looks like you're IFR current!
    I was scribbling too: https://flightaware.com/live/flight/...938Z/KFCM/KFCM
    Writing? Looks more like Sky Scribbling to me.
  • Bill Bridges
    Hi Bill -- <<Procedural Tracks>> I'm not familiar with that as a term of art....can you explain?
  • Scott Dyer DXR/CT
    I grew up on DoD plates and Procedural Tracks have a different meaning to me than when I am using Jepps. The Jepps seem to use them differently so when I see something like the HILT the thought crosses my mine "Do I fly it as published or can I enter like I would normally?"
    Thanks for the clarification.
