Scott Dyer DXR/CT - Did you practice these in your C210? Curious if you attempted to lower the gear after reducing power to idle in the downwind at pattern altitude?
https://www.faa.gov/training_testing...rplane_acs.pdf (Section IV. M)
We'd been practicing these in the C172, as my student will be using two aircraft for the test. She reasoned that she might be requested to do the Power-off 180° in the more complex aircraft, so we tried a few in the C210 yesterday. We first started with reducing power to idle in the downwind, and then lowering the gear. We could never reach the runway successfully, and had to add power. If we lower the gear ahead of the power reduction, it worked out OK.
I reasoned that the ACS doesn't require the gear lowering to be done after simulated power loss, and that she's always going to have her gear down before entering the pattern anyway, so that was going to be acceptable to the examiner to have the gear down ahead of that maneuver.
Just curious if you've tried it. The altitude lose when lowering that gear will get your attention. I assume it is the gear doors acting as big speed brakes.
John
John
