Originally posted by Dave Siciliano
									View Post
		Navy pilot who shot down R MIGs
The early jets were NOT over powered.Originally posted by Dave Siciliano View PostLooks like that had an engine with 5,000 pounds of thrust. The Citation II I flew had two with 2,500 pounds each. :-)
But what I see is the prototype had 5000 pounds of thrust. The production aircraft had 6250.
And yes, centrifugal compressor engine would spool up VERY slowly, especially from idle. J-69 in the T-37 could take 10 seconds from idle to full power. One thing you checked during preflight was the actual spool up times for the engines in the aircraft you were going to fly. I remember 6 seconds was common.
The T-37 had thrust attenuators to allow you to keep the RPM up around 60% for faster response.
Hi Dave,Originally posted by Dave Siciliano View PostLooks like that had an engine with 5,000 pounds of thrust. The Citation II I flew had two with 2,500 pounds each. :-)
Likely the Citation drinks considerably less kerosene also<g>.
When the speed brake is deployed, and you reduce the throttles below 60% RPM (IIRC), there are small panels behind the engines that pop out and deflect the thrust sidewaysOriginally posted by Scott Dyer HPN/NY View Post
How do they work, Terry?
Here is a drawing of one deployed.
When deployed, you kept the engines spooled up, but reduced the thrust. When you got good with the jet, you would "play" the attenuators. Popping them in and out with small throttle movements, without really changing the throttle setting.
1. The early jets were NOT over powered
2. keep the RPM up around 60% for faster response.
re #1 Chuckle, like someone once had said - "NS, L"
and #2 When i was first checked out in the T-33 I distinctly reall being strongly advised/told to - "keep your RPMs up on final so you'll have some response if you need the power!"
