RNAV Arrival
  • RNAV Arrival
    I need to rethink my question and come back later.
    In the above example when NoPT is not present on the inbound Track (WAGNR) can the aircraft turn inbound at the IAF (ORTMN) or must it turn outbound and follow the outbound track to reverse course?
      Bill -- If you are flying the segment from WAGNR to ORTMN, and there is no NOPT on the chart, then you must fly the HILPT. Were you cleared, for example, from somewhere southeast of ORTMN direct to ORTMN and then for the "straight in" approach, then you would not fly the HILPT (unless you received an express clearance to do so). And if you were vectored to final between ORTMN and BARRY you would not fly the course reversal.
      See the AIM: 5−4−9. Procedure Turn and Hold−in−lieu of
      Procedure Turn
      a. A procedure turn is the maneuver prescribed
      when it is necessary to reverse direction to establish
      the aircraft inbound on an intermediate or final
      approach course. The procedure turn or hold−in−
      lieu−of−PT is a required maneuver when it is depicted
      on the approach chart, unless cleared by ATC for a
      straight−in approach. Additionally, the procedure
      turn or hold−in−lieu−of−PT is not permitted when the
      symbol “No PT” is depicted on the initial segment
      being used, when a RADAR VECTOR to the final
      approach course is provided, or when conducting a
      timed approach from a holding fix.
      The altitude
      prescribed for the procedure turn is a minimum
      altitude until the aircraft is established on the inbound
      course. The maneuver must be completed within the
      distance specified in the profile view. For a
      hold−in−lieu−of−PT, the holding pattern direction
      must be flown as depicted and the specified leg
      length/timing must not be exceeded.
        Unless I am missing something, NoPT IS shown on that plate between the IAF at WAGNR and ORTMN. Or are you asking what would be required if it wasn't shown? (Which Scott answered).
          Scott,
          Must the entry into the HILPT be flown as published, or can it be flown by turning outbound on a heading of 114 at ORMAN for one minute then a right turn to reverse course and join the 324 inbound course to ORTMN?
            John,
            I was asking "what would be required if it wasn't shown." I saw a similar approach (MWCR RNAV08) into a non-radar facility this week. It was the first time I had seen a HILT on an RNAV approach.
              Scott,
              You can use any of standard hold entries in to the published hold which would include the teardrop entry you proposed. The entry into a published hold is not mandated, only the hold itself.
                Scott,
                Bill - Andy covered it. Just remember your maximum holding speeds as you simulate flying jet aircraft.
                  Thanks, Andy, I was out doing a little skywriting this afternoon.
                    Bill - Andy covered it....
                    I grew up on DoD plates and Procedural Tracks have a different meaning to me than when I am using Jepps. The Jepps seem to use them differently so when I see something like the HILT the thought crosses my mine "Do I fly it as published or can I enter like I would normally?"
                    Thanks for the clarification.
                      Hi Bill -- <<Procedural Tracks>> I'm not familiar with that as a term of art....can you explain?
                        Procedural Track a/k/a Procedure Track. When I see a heavy, dark line with an arrow head that would indicate to me that I must fly that course. In the HILT example above I would not have performed a tear drop entry but would have flown the outbound course of 144.
                        When I see what I would consider a Procedure Turn symbol I almost always use a tear drop because it works best with my simple mind. When I see a Jepp (and I may be misreading the IAP) the Procedure Turn looks like a Procedure Track to me and I must fly the course as published.
                          Writing? Looks more like Sky Scribbling to me.
                            I was scribbling too: https://flightaware.com/live/flight/...938Z/KFCM/KFCM
                              I noticed. Looks like you're IFR current!
